Brand New M+
-Able to set it up to a local Wi-Fi no problems.
-Able to se it get a new IP of 10.10.10.195.
-However, it says it is not set up or the firmware is out of date
-Used the Firmware Tool but it can’t find after I set it up in Firmware update mode.
We regularly release new firmware versions. Likely, a new one came out while the receiver was on its way to you.
If you can access Reach in ReachView 3 when it works in the hotspot mode, please walk through our First setup guide. I think it should help. In case of any difficulties, let me know at which step they happen.
