Hi all .
Am having issues after updating my rs2 to the latest dev firm ware.
1- I can’t connect to a known wifi network yet it’s on.
2- I can’t connect to NTRIP neither can I download a source list .
Here is a simple system report.
Do I understand correctly that you were able to connect to this network prior to the update? Please note that Reach receivers are working with the 2.4 GHz networks only.
May I ask you to specify if you provide the unit with the internet via the cellular modem? Is there any indication of the error that prevents the unit from connecting to the NTRIP service?
Hi Polina that’s the screen shot of the network am trying to connect to.
Everything worked perfectly before the update
And yes the rs2 has full internet access because it even shares during hotspot mode.
May I ask you to specify if you tried different Wi-Fi networks to update? Have you tried the hotspot of your smartphone?
Would it be possible to describe the LED status of the receiver while you’re trying to connect it to the Wi-Fi network? Does the LED network start blinking rapidly in search of the network?
Hello Polina .
It’s the smart phone am using .
The machine blinks blue rapidly trying to connect to the network but after it fails and returns to solid white ( hotspot mode)
Hi Polina - regarding mattfrederick6’s wifi issues this seems identical to my posted problem after upgrade. I aslo tried flashing one unit and have the same further problem getting past the non working hotspot. Thanks.
Hi Polina
I have tried more wifi networks but some work others don’t so it’s a gamble.
I was waiting for @mikhail.goryachev mikhail to give me the results after examining the full system report
