Hi, I am having issues with connecting the Rover with the Base to conduct survey points.
The Base has a Sim card in it and the app is used through an Ipad. I am also having issues with a samsung phone.
I expected that the Rover would automatically connect with the Base?
Connecting from base to rover happens via LoRa or an internet connection i.e. over NTRIP. While you are able to connect via wifi, you won’t get a usable distance out of it.
The next RS2 Getting Started Webinar is on the 19th. Please join and we can show you some basics like this and answer your questions.
Hi @gcorlett,
Do you want to establish the connection via LoRa radio or via the Internet?
If you use LoRa, you can check our docs on Base and rover setup.
Hi Tatiana
Thanks, I managed to get a connection through LoRa.
