I have everything powered up and I’m trying to connect to mission planner on a windoughs machine.
Navio+ on raspberry pi 2B with IP: 192.168.1.80 (Mission Planner is on Windoughs machine 192.168.1.81)
running command
sudo ArduPlane -A -C udp:192.168.1.81:14550
causes an endless stream of wild ASCII characters to appear on the screen, matrix style. Makes me wonder why the UDP stream needed to be output via stdout.
Anyways, when I go into Mission Planner and hit connect (UDP selected) I confirm the Port 14550 and then it is just “waiting for UDP” and nothing happens.
Obviously both can ping each other and I disable IPv6 systemwide on the raspberry pi.
