Running ReachView version v2.21.2
Changing base corrections from TCP to serial “hangs”.
Log is showing:
Dec 25 12:58:41 reachbs reachview[788]: [2019-12-25 12:58:41,184] [ INFO] --- Got websocket message: apply configuration, args: ({u'base mode': {u'output': {u'type': u'serial', u'format': u'rtcm3', u'enabled': True, u'path': u'serial://ttyMFD2:57600:8:n:1:off#rtcm3'}}},) (logs.py:27)
Dec 25 12:58:41 reachbs reachview[788]: Exception in thread Thread-220:
Dec 25 12:58:41 reachbs reachview[788]: Traceback (most recent call last):
Dec 25 12:58:41 reachbs reachview[788]: File "/usr/lib/python2.7/threading.py", line 801, in __bootstrap_inner
Dec 25 12:58:41 reachbs reachview[788]: self.run()
Dec 25 12:58:41 reachbs reachview[788]: File "/usr/lib/python2.7/threading.py", line 754, in run
Dec 25 12:58:41 reachbs reachview[788]: self.__target(*self.__args, **self.__kwargs)
Dec 25 12:58:41 reachbs reachview[788]: File "/usr/lib/python2.7/site-packages/socketio/server.py", line 640, in _handle_event_internal
Dec 25 12:58:41 reachbs reachview[788]: r = server._trigger_event(data[0], namespace, sid, *data[1:])
Dec 25 12:58:41 reachbs reachview[788]: File "/usr/lib/python2.7/site-packages/socketio/server.py", line 669, in _trigger_event
Dec 25 12:58:41 reachbs reachview[788]: return self.handlers[namespace][event](*args)
Dec 25 12:58:41 reachbs reachview[788]: File "/usr/lib/python2.7/site-packages/flask_socketio/__init__.py", line 213, in _handler
Dec 25 12:58:41 reachbs reachview[788]: *args)
Dec 25 12:58:41 reachbs reachview[788]: File "build/lib/reachview/app/logs.py", line 28, in socketio_wrapper
Dec 25 12:58:41 reachbs reachview[788]: File "/usr/lib/python2.7/site-packages/flask_socketio/__init__.py", line 574, in _handle_event
Dec 25 12:58:41 reachbs reachview[788]: ret = handler(*args)
Dec 25 12:58:41 reachbs reachview[788]: File "build/lib/reachview/app/configuration/events.py", line 62, in configure
Dec 25 12:58:41 reachbs reachview[788]: File "build/lib/reachview/app/configuration/converters.py", line 38, in convert_V0_to_V1
Dec 25 12:58:41 reachbs reachview[788]: File "build/lib/reachview/app/configuration/converters.py", line 60, in convert
Dec 25 12:58:41 reachbs reachview[788]: File "build/lib/reachview/app/configuration/converters_V0_to_V1.py", line 224, in convert
Dec 25 12:58:41 reachbs reachview[788]: File "build/lib/reachview/app/configuration/converters_V0_to_V1.py", line 233, in _convert_output
Dec 25 12:58:41 reachbs reachview[788]: File "build/lib/reachview/app/configuration/converters_V0_to_V1.py", line 39, in convert
Dec 25 12:58:41 reachbs reachview[788]: File "build/lib/reachview/app/configuration/converters_V0_to_V1.py", line 54, in _parse_path_by_type
Dec 25 12:58:41 reachbs reachview[788]: File "build/lib/reachview/app/configuration/converters_V0_to_V1.py", line 63, in _parse_serial
Dec 25 12:58:41 reachbs reachview[788]: KeyError: u'serial'
Don’t seem to remember having this issue in previous version. Will down grade and check if this is ok.
