Before the Update I didn’t have this problem.
At the moment the LED’s are flashing slowly in this way: three times red and one time blue (for the client mode) and 3 times red and one time white (for the hotspot mode).
The problem is the same while trying to access either from my laptop or my mobile in either modes hotspot and client.
Edit: I already rebooted several times the module and also it has a clear view to the sky since it is directly on the roof.
I checked the ip and it is the same, and if it were a different IP I guess I would get an error when getting into reach_ip:5000. But instead I actually get access to the Test, WiFi, and updates site.
Agree with David. You can use our ReachView 3 app to find out Reach’s IP address in the network.
To work with ReachView 3, you need to get the latest stable firmware version on Reach which is 26.2. The only way to update your Reach Module to this version is to reflash the device as described in this guide.
