I have been having problems with Reach view in survey mode.
My phone is connected directly to the Reach M+ hotspot and I cannot go back into the same survey project in order to add more points, so I had to save each point as a separate project which I will have to pull together in post.
Now I am trying to export the files and Reach View does not respond for any file types. The message, “Project Export: Project is being exported please wait” appears but does nothing.
If anyone has any solutions to the above or knows how I can directly pull files from the Reach to my computer without Reachview that would be great. I cannot afford to have this happen in the field every time.
There is only one wi-fi network it could be joined to and it still isn’t visible when my phone is also connectd to that network.
I still have not been able to connect to the Reach, is there a way I can switch it off client mode without simply walking out of range of the wi-fi?
The issues with collecting points has happened the last 2 surveys I have tried to carry out. This is the first time I have eperienced problems downloading data.
