Hello,
I have a persisting issue with the Navio2 boards. I want to initialise 8 channels on the servo rail for using them as PWM outputs. I am setting the up in QtCreator. I cannot enable all the 8 channels, but maximum 2 of them (and even these 2 sometimes do not work). I have set the QtCreator to run the program in terminal, as the initialisation ALWAYS fails if I run the program normally.
I am using Raspberry Pi Model 3B with Emlid Raspbian from 2017, updated and upgraded to the latest version.
here are some messages from some commands in the terminal:
sudo vcdbg log msg 2>&1 | grep -C5 rcio
002214.833: dtparam: spi=on
002282.301: Loaded overlay ‘spi0-4cs’
002350.276: Loaded overlay ‘spi1-1cs’
002350.291: dtparam: cs0_pin=16
002351.094: dtparam: cs0_spidev=disabled
002420.252: Loaded overlay ‘rcio’
002456.346: Loaded overlay ‘navio-rgb’
002456.380: dtparam: i2c1=on
002466.668: dtparam: i2c1_baudrate=1000000
003506.431: Device tree loaded to 0x2effb200 (size 0x4d8c)
003512.008: gpioman: gpioman_get_pin_num: pin SDCARD_CONTROL_POWER not defined
dmesg | grep rcio
[ 4.599884] rcio_core: loading out-of-tree module taints kernel.
[ 4.626700] rcio spi1.0: rcio_status: Firmware CRC: 0xb09979ae
[ 4.627780] rcio spi1.0: rcio_status: Board type: 0x0 (navio2)
[ 4.628697] rcio spi1.0: rcio_status: Git hash: dae830a
[ 4.629946] rcio spi1.0: rcio_pwm: Advanced frequency configuration is suppor ted on this firmware
[ 4.632632] rcio spi1.0: rcio_pwm: updated freq on grp 0 to 50
[ 4.633537] rcio spi1.0: rcio_pwm: updated freq on grp 1 to 50
[ 4.637355] rcio spi1.0: rcio_pwm: updated freq on grp 2 to 50
[ 4.638343] rcio spi1.0: rcio_pwm: updated freq on grp 3 to 50
[ 4.653493] rcio spi1.0: rcio_pwm: PWM probe success
[ 4.654721] rcio spi1.0: rcio_gpio: GPIO is supported on this firmware
[ 4.654773] rcio spi1.0: rcio_gpio: registered gpio module
[ 4.655323] rcio spi1.0: rcio_gpio: gpiochip added successfully under gpio500
ls /boot/overlays/rcio*
/boot/overlays/rcio.dtbo
lsmod
Module Size Used by
fuse 95787 3
bluetooth 528706 0
binfmt_misc 10972 1
rcio_spi 3185 0
rcio_core 28929 1 rcio_spi
spidev 8534 0
brcmfmac 290629 0
brcmutil 10583 1 brcmfmac
cfg80211 576971 1 brcmfmac
rfkill 20614 4 bluetooth,cfg80211
i2c_bcm2835 7231 0
spi_bcm2835aux 5655 0
spi_bcm2835 8118 0
bcm2835_gpiomem 3900 0
uio_pdrv_genirq 3885 0
fixed 3563 0
uio 10268 1 uio_pdrv_genirq
i2c_dev 8759 0
ip_tables 13314 0
x_tables 21300 1 ip_tables
ipv6 414219 32
uname -a
Linux Drive_Module 4.9.45-94f47ec-emlid-v7+ #4 SMP PREEMPT Wed Aug 30 18:17:43 M SK 2017 armv7l GNU/Linux
pi@remote:~ $ sudo vcdbg log msg 2>&1 | grep -C5 rcio
If you have any ideas of how I can solve this issue, please let me know.
Many thanks,
minu
