Wifi connectivity issues with the navio2 board.
Hello!
Please, specify as more details as possible.
Hi !
I have a navio2 with a pi3. I have tried to setup a static ip as on the navio2 by modifying the /boot/wpa_supplicant.conf file to the ssid of the static ip in the wifi router as suggested in the documentation.
The issues I am facing are follows:
The method as suggested in the guide does not work. I have tried several times (replaced the pi3 + flashed the image on new cards + replaced the navio2 )
Why is there an intwifi0 instead of the default wlan0 as as pi3 do?
I came across this as I searched online for possible solutions to the assignment of static ip on rpi3 one of them suggested modifying the /etc/network/interfaces config and disabling dhcpcd service. This method worked for static ip assignment using ethernet. But the wifi access method still fails for ping and ssh ( ssh server on the pi3 was enabled when I tried this) -
The documentation does not mention any alternative methods for accessing the navio2 except wifi and using tmux is really not intuitive with US keyboard layout.
Please advise on the following:
- How to get the intwifi0 method working for ssh into the navio2 ?
- If you could provide alternative strategies for using wifi that would be terrific!!
- How are the ros messages been transmitted (over wifi or what other method of communication is used) with the ground control station ?
Thanks in advance
It was needed in order to support Wi-Fi broadcast feature.
Could you please share the contents of /boot/wpa_supplicant.conf
? You can try populating the file like this when connected to a Raspberry Pi (either via Ethernet or HDMI).
Could you please elaborate? The default layout is en_GB.UTF8 (the same as from Raspberry Pi Foundation). In order to generate a locale you can either use raspi-config
or just uncomment an appropriate line in /etc/locale.gen
and then run sudo locale-gen
and you’re good to go.
Here’s an overview that explains how everything’s set up. The gist being: mavros connects over a local UDP endpoint to ArduPilot and then to a endpoint on a GCS specified in a _gcs_url
There’s a project called create_ap that I find quite useful from time to time. It creates a Wi-Fi hotspot.
Hope it helps.
I am not sure if this helps, but in order to connect to Navio2/Rpi3 image to my home network, I do two things (after raspi-config change localisation:wifi to home country, CA, for me):
(1) As suggested, I edit /boot/wpa_supplicant.conf to add the SSID=“xxxxx” and PSK=“xxxxx” of my wifi network, then
(2) I edit /etc/wpa_supplicant/wpa_supplicant.conf and add the same information as above.
Reboot.
This works every time for me.
John
Thanks for the clarification
The contents od /boot/wpa_supplicant.conf
file are as follows
> country=GB
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev update_config=1 network={ ssid="NAMEOFWIFI" key_mgmt=None #psk="emrooftop" #psk=defaultkey_that_came_along_with_the_board }
I will try that and get back to you.
Thanks for the info. I will check it out.
I will check that out.
Please let me know if the wpa_supplicant file is written correctly.
Thanks
It looks as if you didn’t specify your password after all at all.
I’m linking this once more. So basically you’ll need this:
sudo bash -c "wpa_passphrase NAMEOFWIFI yourpassword >> /boot/wpa_supplicant.conf
I don’t have a password. Its not WPA secured. Do I need to have the router to be secured for this to work?
Okay, I haven’t taken this opportunity into account.
In that case you need this:
network={
ssid="myssid"
key_mgmt=NONE
Is the network 5GHz or 2.4GHz? If the former, the built-in Raspberry Pi 3’s Wi-Fi will not work.
I will try this
And for the wifi its on 2.4GHz
