I am trying to connect the new RS2 to my iPhone X hotspot for NTRIP correction as I do with my RS+. when I try to connect the blue light flashes on the RS2 and I will see the link symbol appear on the iPhone for a few seconds then it goes away. A few seconds later the link appears again then again goes away and the RS goes into hotspot mode. I have tried this with both my iPhone X and iPad Pro both on IOS 13 with the same results. If I connect to my ho e WiFi it works fine.
If you haven’t tried already, try and simplify your SSID of your phone. No spaces, no special characters.
I changed the SSID and password on my iPhone to all lowercase, no spaces or special characters but still cannot get it to connect. I also tried my Reach RS+ which has worked reliably in the past and had a similar problem. I am able to connect the RS+ if I connect to the RS+ Internal hotspot from my iPad and tell it to connect to the iPhone hotspot but this isn’t working reliably. I believe this may be an iOS13 issue.
Hi @aerial.image,
Please make sure your iPhone isn’t connected to any Wi-Fi network while it’s in the hotspot mode.
May I ask you to follow the steps below to double-check everything? This is a strange issue and usually Reach works fine with iOS devices.
- Delete your iPhone/iPad networks on the Reach
- Add a hidden network and doublecheck your login/password
- Press the Connect button and shutdown your Reach
- Enable mobile hotspot
- Turn Reach on
Reach should connect to the mobile hotspot.
Please keep us posted.
Thr issue I had was that it would occasionally connect, maybe 1 in 10 times. IT appears it is a change in iOS13 that caused it. With the following workflow I can reliably connect now.
- Ensure HotSpot is turned on
- Ensure connection in Reach is configured correctly And other nearby WiFi such as home network are removed
- On iPhone open control center and hard press on WiFi button to open WiFi settings
- There is now a button that says Personal HotSpot. Press this button to make iPhone discoverable
- Power cycle reach and it connects.
I am having similar issues and I have found that if I connect a different device(laptop, tablet) to the hots pot prior to connecting the GPS modules they will connect just fine.
