Cannot connect to AUSCORS
Reach RS2+
Internet connection via Wifi
Firmware version: 30
Emlid Flow (Android)
I tried to connect to:
ntrip.data.gnss.ga.gov.au:443/CLYT00AUS0
I tested the system outdoor.
It shows waiting for connections.
I am not sure what I did wrong. I am also not sure whether I need to install the certificate from government site.
Please help. Thank you.
Hi @xyang,
Welcome to our community forum!
I see that the firmware and the app are updated to the latest versions, so there shouldn’t be any issues from this side. Let’s also check the following:
  • The NTRIP credentials. Do you enter ntrip.data.gnss.ga.gov.au as the address, 443 as the port, and CLYT00AUS0 as the mount point?
  • The Internet connection stability. You can connect Reach to another Wi-Fi network or a mobile hotspot to ensure the issue is not on the network side.
A post was split to a new topic: Can’t connect to AUSCORS
