Hello I’m using the new navio2 release RPI image.
I also saw the article ‘Can’t connect to the network’, but don’t understand the solution.
( It does not specify how to reconfigure or something)
I’ve changed the /boot/wpa_supplicant.conf file. i didn’t make typo something like WPA-PSK.
And still the wifi does not work. What should i do make it work properly?
And I think you need to debug and re-release the image on the website, because there are bugs like this.
Oh i’m sorry, there was some bug, which i made.
I was trying to use wifi-direct on the Navio RPI, and in the middle of doing that, there were some problems.
In fact, i’m struggling to make the wifi-direct work, because of the changed network interface name.
I will post another issue later related to this.
As you can see, i thought it’s working but actually it’s not working with wifi.
It’s same problem in another post, which i mentioned at the first writing above. ‘Can’t connect to the network’.
At the post, the part of solution related to dhcpcd is mentioned, but not detailed.
For more information, the IP address is assigned with the intwifi0,
but actually the router does not recognize it, and the ssh does not work with wifi.
(I think the network is not working actually)
same problem with USB wifi dongle. DHCP gets an address, can ping it, but cannot actually use it. Configured SSH to bind to all IP’s and disabled intwifi0.
Same issue here, been bashing my head on the keyboard
I noticed when I took a peep @ /etc/network/interfaces there were 3 references to /etc/wpa_supplicant/wpa_supplicant.conf in there.
I was labouring under the impression that the correct file for this was located @ /boot/wpa_supplicant.conf This the file we are told to add our network details to.
Can someone with greater knowledge of Linux guide me out of the fog.
I have reflasked my SD card for around 4 times and the wifi issue has been always experienced.
I am using Etcher (v1.0.0-rc.5) on Mac Os Sierra (10.12) to reflash my SD Card and the image that I am using is the release 20170323 (which is the latest stable).
I will try to reflask one more time and I will share my configuration.
It’d be great. This will eliminate the hardware problems. I mean, this is the image I use personally and reflash SD cards every day and it works out of the box.
I just ordered a brand new RPI3 and a wifi dongle to test if it is something related to the built-in wifi.
They will be delivered tomorrow. I will let know my findings as soon as I can perform my test.
if you want to use wifi broadcaster make sure it is compatible here or here
i do believe you won’t need the wifi dongle otherwise…also some of them are capeable of long range transmission!
