Cannot connect drone (DJI Mavic 3 Enterprise) to RS4 hotspot
I am attempting to use my new RS4 as an RTK base for my DJI Mavic 3 Enterprise via local NTRIP by connecting the drone to the RS4’s hotspot. However, the RS4’s hotspot does not appear in the list of wireless networks found by the drone. The drone sees other networks just fine, and my other devices see the RS4’s network just fine. I tried adding the network manually to the drone, but it says “network not in range” even though I’m right next to it and my other devices can connect.
This connection approach worked fine with my old RS2.
In the end, I found a workaround by connecting the RS4 and the drone to my phone’s hotspot, but I’d like to avoid the need for this third device.
Is this expected behavior, or is it possible I have a defective RS4?
Thank you.
Did you update the firmware?
I remember in the previous release there was something about hot spot discoverability.
Massimo
Hi @djyoung ,
I would like to look into this issue if the recommendation from @studiodemarchi.net didn’t solve it.
For that, please download and send me a Full system report from the device to [email protected].
Thank you both and sorry for the delay. Yes, the firmware was already updated and my RS4 was able to see all available networks. It was actually my drone that was unable to see the RS4 network. I am away from my equipment for two weeks but I have this on my list to submit as soon as I’m back. Thank you again.
Was this issue resolved? I am having the same issue
Hi @trevor1 ,
Looking at the past thread, it looks like the issue was that the drone couldn’t detect the receiver’s hotspot.
Have you had a chance to try the suggestion from @studiodemarchi.net? Specifically, make sure the receiver is running the latest firmware, and also test the Local NTRIP setup on a different Wi-Fi network.
The issue is that my drone controller does not recognize the receiver’s hotspot (sometimes). Sometimes the controller will see the hotspot. I found documentation that states that this is because of the channel the receiver chooses to broadcast as the hotspot. If it chooses lower channels, the receiver recognizes it. If it chooses higher channels, the controller does not recognize it.
The NTRIP works fine on a different wifi network, but I need to use it in remote locations without wifi or cell coverage (to establish a hotspot with my phone).
I found a relatively simple and inexpensive solution by purchasing a portable router and using it to establish a network that the controller and base can connect to.
@trevor1 ,
I did a bit of digging, and my checks do align with your findings. With the RS4, it is hardcoded to work with a 5 GHz Wi-Fi network, including its own hotspot. With this, the channel the receiver uses can get crowded at times, which can limit connectivity, as you mentioned. I believe this is what is happening here.
We do have a feature request to add the option to change hotspot frequency, and I have added yours as a +1, as I believe this can come in handy here. However, I am glad to hear that you have a workaround for working with a router for Wi-Fi.
