just starting, stuck already. With both units in my Reach RTK Kit, I have the following:
I can connect to them when they are in hotspot mode, I can enter my wifi network details, and I can find the devices using Zenmap (on Windows 10 laptop) and Fing (on Android mobile).
Here is what Zenmap gives me on Windows:
Nmap scan report for new-host-2.local (192.168.2.139)
Host is up (0.094s latency).
All 100 scanned ports on new-host-2.local (192.168.2.139) are filtered
MAC Address: FC:DB:B3:8B:45:1D (Murata Manufacturing)
(for the other device, it’s 192.168.2.138 and new-host.local)
The device address is solid green, as long as I put the antenna somewhere where it sees the sky.
What am I doing wrong?
I have seen advice about reflashing, but have not attempted this, partially because the on tutorial found suggested pushing a power button on the device which I cannot even seem to find…
I’m sorry, I can’t provide a Firmware version, not sure how I would obtain it.
Hmm,
afraid that didn’t work either. Not sure if reflash was successful, I went through the steps as described on the website, including the workaround, but even though it completed without error messages, in the end the screen still showed “Firmware not detected”
Slight update:
It now seems the blink pattern is: white (with hints of red & blue on the edges) alternating with green, each lasting 2-3 seconds before switching to the other
Yes, I have added my wireless network details several times.
When connected to my wireless network, the reach shows up in the Zenmap scan, so presumably this means that on some level it is discoverable and hence connected to my wifi network?
Actually, just now when it was white/green blinking, it was indeed in hotspot mode, but now I reconnected it to my wireless and it’s blinking blue/green (alternating). And still times out
You should be good to go, something is not right indeed
Also, may i ask what your wifi password is and name of accesspoint?
If it has any rare letters or signe, it may cause reach to halt at handshake.
Please try a simple pass and AP name if els fails
Go things to work just this moment!!
Took device to work, used the work wifi, that seems to have made the difference. So I guess for now the message for anyone with a similar problem might be:
Try a different wifi network… @TB_RTK, thank you so much for your help!
@TB_RTK
Regarding your last tip above, strangely I would have thought that the work network is much less likely to succeed. It has a more complex SSID name and password, all sorts of firewall rules etc. Notably, in my work network, the Reach shows up with an IP address starting with “10.” whereas at home it starts with "192."
Btw, is there any way to force the Reach to get back to hotspot mode if I cannot connect to it through the wifi? I’d try to play with changing the wifi settings on my Reach to see if any combination works with my home wifi, but currently I need to flash the firmware to get it back to hotspot mode (as the Reach seems to think it’s working fine on my Wifi, even though it’s not visible for my browser or my Reach app on Android)?
You should not connect Reach to a network that hands out 192.168.2.xx addresses. Reach uses that subnet for ethernet-over-USB. If possible, change your WiFi/router settings to use a different subnet, like 192.168.3.xx. If you can’t do that, then you will need to change the hard-coded config file within Reach to make it use a different subnet for ethernet-over-USB.
What is happening is that Reach hears you making a request over WiFi and Reach replies back over USB. Since you are not connected to the USB, you don’t get the reply.
Oooh, now that would explain the situation! If this is the case then it might be beneficial for others to have this in the documentation.
I just googled this and found you had already helped someone else with a similar issue, in
Perhaps this should either be fixed or documented - how would I raise this issue?
Thanks a lot, I will see how I can now fix this (without upsetting the flatmates who share the wifi I’m on…)
