hello,
i am trying to figure out that if we can use a single reach module as base and 2 or 3 reach module as rover.
can they communicate over serial interface if i use point to multipoint radio configuration?
i will connect a base’s serial port with radio’s serial port (Master or Access point), then i will connect another two reach module to other two radio (slave or client) .
my radio’s will communicate with each other but can i get correction data from the base to multiple rover?
As long as you’re in the radius of signal there’s no problem with getting corrections to as many rovers as you need.
15km to L1
Hey Omkar, may I know the hardware set up you used for the point to multipoint radio configuration?
