We recently carried out a LiDAR mission using the RS2 to collect Rinex data.
When post processing the trajectory we didn’t gett FIX at all and had to use Rinex data from a reference station from the Public Mapping Authorities in order to achieve FIX solution.
Is it possible (for a fact) that the RS2 can/have been affected by the high voltage transmission lines nearby?
Yeah, the high voltage lines usually affect the signal reception badly, so it can be a case. You can send the raw data from both base and rover to us via support@emlid.com so that we can take a look and give you more detail on observations quality.
Hi Martin,
According to the documentation Yes it can be affected ‘Electronic devices may produce RF noise that could affect the reception of the GNSS signal. Keep all electronics as far as possible from Reach’.
Just out curiousity, would you be able to either make the obs file available here, or send it to me for analysis?
It would be cool to see if the troubles can be seen using RTKplot and the charts and graphs it provides.
