Could someone please confirm that an RS2+ can output NMEA and PPS through RS232 connection? It looks like one would just need to wire up pin 5 on the connector cable; however, aside from the wiring diagram, I don’t see any mention of PPS in the documentation and some older threads suggest it might not be supported. thanks, -Del
Hi Del,
Welcome back to the forum!
Sure, you can get the PPS signal from the bottom connector of Reach RS2+. You can configure the position streaming of NMEA from the bottom connector as well.
