I just unboxed a Reach RS.
When I started to follow the guidelines to connect the RS to the Wifi it didn’t worked very well.
After some troubles I got it connected to my WiFi network. I can see it by using Fing. When I type the IP adres in the address bar Chrome says it’s connected but it does not response. When I use my smartphone (Android) with the app, it’s says there is no RS in the network.
The led status says the following: App running, client Wi-Fi mode.
192.168.2.x subnet is reserved inside Reach for Ethernet connections, unfortunately seldom Wi-Fi networks might have this subnet as well. You will need to perform initial setup in a different Wi-Fi, sorry about that. Hotspot on a phone will work just fine.
What do you mean when you say “perform initial setup in a different Wi-Fi”? Please be specific – simple step by simple step. I’m a Mac/Apple user. I don’t understand technical stuff. Thanks!
You wanna delete wifi you have added to this picture and ad a new one that has a IP for Reach different from your previous (192.168.2.5). You do this by either configurate your router/AP to hand out IP in the range of 192.168.2.XXX and NOT 192.168.2.X OR If you are not able to do this you can try another router/AP and see if it creates a different IP for your Reach
Yes, it appears on both the iPhone and iPad now. But it had “disappeared” for some time. Been dealing with Emlid online customer service for two weeks or more.
