pi@navio-rpi ~ $ sudo ArduCopter-quad -A udp:192.168.11.2:14550 -C /dev/ttyAMA0
ArduCopter-quad: /lib/arm-linux-gnueabihf/libc.so.6: version `GLIBC_2.15’ not found (required by ArduCopter-quad)
He used to update the following vessel.
#!/bin/bash
Old build from Emlid:
#wget http://emlid.com/files/APM/apm.deb
#sudo dpkg --install apm.deb
#rm apm.deb
Remove any old build
sudo dpkg --remove apm
New build direct from DIY Drones/APM master
sudo rm /opt/apm --recursive --force
sudo mkdir /opt/apm
sudo mkdir /opt/apm/bin
cd /opt/apm/bin
sudo wget http://firmware.diydrones.com/Plane/latest/navio/ArduPlane.elf --output-document=ArduPlane
sudo wget http://firmware.diydrones.com/Copter/latest/navio-heli/ArduCopter.elf --output-document=ArduCopter-heli
sudo wget http://firmware.diydrones.com/Copter/latest/navio-hexa/ArduCopter.elf --output-document=ArduCopter-hexa
sudo wget http://firmware.diydrones.com/Copter/latest/navio-octa-quad/ArduCopter.elf --output-document=ArduCopter-octa
sudo wget http://firmware.diydrones.com/Copter/latest/navio-octa/ArduCopter.elf --output-document=ArduCopter-octa-quad
sudo wget http://firmware.diydrones.com/Copter/latest/navio-quad/ArduCopter.elf --output-document=ArduCopter-quad
sudo wget http://firmware.diydrones.com/Copter/latest/navio-tri/ArduCopter.elf --output-document=ArduCopter-tri
sudo wget http://firmware.diydrones.com/Copter/latest/navio-y6/ArduCopter.elf --output-document=ArduCopter-y6
sudo wget http://firmware.diydrones.com/Rover/latest/navio/APMrover2.elf --output-document=APMrover2
cd ~
sudo chmod +x /opt/apm/bin/*
sudo rm /usr/bin/ArduPlane* --force
sudo rm /usr/bin/ArduCopter* --force
sudo rm /usr/bin/APMrover* --force
sudo ln --symbolic /opt/apm/bin/ArduPlane /usr/bin/ArduPlane
sudo ln --symbolic /opt/apm/bin/ArduCopter-heli /usr/bin/ArduCopter-heli
sudo ln --symbolic /opt/apm/bin/ArduCopter-hexa /usr/bin/ArduCopter-hexa
sudo ln --symbolic /opt/apm/bin/ArduCopter-octa /usr/bin/ArduCopter-octa
sudo ln --symbolic /opt/apm/bin/ArduCopter-octa-quad /usr/bin/ArduCopter-octa-quad
sudo ln --symbolic /opt/apm/bin/ArduCopter-quad /usr/bin/ArduCopter-quad
sudo ln --symbolic /opt/apm/bin/ArduCopter-tri /usr/bin/ArduCopter-tri
sudo ln --symbolic /opt/apm/bin/ArduCopter-y6 /usr/bin/ArduCopter-y6
sudo ln --symbolic /opt/apm/bin/APMrover2 /usr/bin/APMrover2
Thank you in advance for your help
