I am not able to use the full 32gb of the ssd. Also, I am not able to extend the Linux partition which the image has. I need to extend the â/â (root) partition so that i am able to install the software I need. I tried using fdisk, parted and gparted several times, but, it does not work.
have anyone extended the default partition created by the navio image?
i meant ssd card. it has 32gb. so, when I install the navio2 image into the 32g sd card. All I have is less space to install other things like ardupilot, node.js and modules. it is out of space. so, I need to utilize my full 32g space. so, I created a new partition and formatted it to fat32 and mounted it. but, the â/â parition is out of disk space.
well, now, I have reformatted my sd card. installed raspbian os and installed node.js⊠but, obviouslly, apt-get install apm-navio2 does not work since it cannot find it. (and yes, I I did follow the instructions from the raspberry website)
