how to make custom Android kernel for raspberry pi work with navio 2
Hi @hatemahmoudi,
Sorry for the delayed response.
I’d recommend using pi-gen tool to build your custom Navio2 image.
Our kernel source code might be useful as well.
first, thank u for the importance u have given to my subject , but in my case , with
the Android kernel different a bit than normal Linux.
so i have applied the rcio patch for my kernel with some modifications in the “bcm2709_navio2_defconfig”(CONFIG_VMSPLIT_2G=m ,CONFIG_I2C_BCM2708=y,CONFIG_I2C_BCM2835=y,CONFIG_I2C_GPIO=y,CONFIG_DRM=y, CONFIG_DRM_VC4=y) then i integrated the RCIO kernel module source code into my kernel code base and the build has been completed successfully , but the problem when i lunch the arducopter i get this big “LinuxPWM_Sysfs:Unable to open file /sys/class/pwm/pwmchip0/pwm0/duty_cycle: No such file or directory”
Hi @hatemahmoudi,
I’m afraid I barely can help you compile the Android kernel. At the moment, we only provide the Buster Raspbian image.
