Hi.
I’m trying to build from source on the raspberry according to this guide: https://docs.emlid.com/navio2/common/ardupilot/building-from-sources/
I have followed the guide completely but adding git submodule update --init --recursive since that is the only way to make it clone the pymavlink submodule too under modules/mavlink/pymavlink.
I run the Waf build process exactly as the guide says but I get this build error around halfway through:
My goal is to modify the ArduCopter firmware to add a new Mavlink message and then modify one of the flight modes to include a new controller to position the drone based on data given from an object detection code to the flightmode using this custom message but I need to be able to build it first.
Any help is appreciated!
