Good morning
Yesterday i made the update of my two unit reach rs + , and to day i can’t work my rover and my bases switch of alone when it’s switch one i can’t connect my ipad or my phone with my rover and ReachView i see my rover but i have a message of ReachView can’t connect to reach_rover i can’t please help me i have to finish a survey for the client of my compagnie
Hi Adis,
Please confirm if I get the unit state right:
- The RS+ device is running hotpost: blue LED on the RS+ device is solid
- You can connect your phone to the network reach:XX:XX
- You open the ReachView 3 app and then can’t access the device
If this is correct, please try to open any browser on your phone and go to 192.168.42.1: it should open the web version of ReachView.
It’d be also great to have a screencast showing the issue so that we could dig into the reasons for it.
Hello i tried this solution and same result i can’t connect to tjs rover even If i tried whith IP adresse and after 5 MIM the rover Switch off alone
Before were you
Connecting your phone to the reach hotspot?,
Or Connecting the reach to the phone hotspot?
Yes i tried the two way in direct connections and with the hotspost of my cell phone
And when i restart After 5 min reach rover Switch off alone
Adis,
Just to make sure it is not the issue of phone disconnecting from your Reach device: do you click on the Keep button after the notification shown on the last screenshot appears?
Is note a phone issue because i have thé same result with my iPad and i tried whith my computer same result before the update i Nevers have this problème
I understand but why after 5 min the rover Switch off alone before the update i Nevers have this problème
Hi this the report i restart After 4h
Simple system report
app version: '26.0'
current_network:
ip: 192.168.42.1
security: wpa-psk
ssid: reach-rover:5B:6D
enabled: true
mode: hotspot
base_mode:
base_coordinates:
accumulation: 120
mode: single-and-hold
output:
io_type: tcpsvr
settings:
cloud:
mount_point: ''
lora:
air_rate: 9.1099999999999994
frequency: 866000
output_power: 20
ntripsvr:
address: ''
mount_point: ''
password: '***'
port: -1
serial:
baud_rate: 38400
device: ttyEXTS0
tcpcli:
address: localhost
port: 9001
tcpsvr:
port: 9000
rtcm3_messages:
message_1002:
enabled: true
frequency: 1
message_1006:
enabled: true
frequency: 0.10000000000000001
message_1010:
enabled: true
frequency: 1
message_1097:
enabled: false
frequency: 1
message_1107:
enabled: false
frequency: 1
message_1117:
enabled: false
frequency: 1
message_1127:
enabled: false
frequency: 1
bluetooth:
enabled: true
pairing:
discoverable: true
pin: '***'
correction_input:
base_corrections:
io_type: lora
settings:
bluetooth:
send_position_to_base: false
cloud:
mount_point: ''
send_position_to_base: true
lora:
air_rate: 4.5599999999999996
frequency: 866000
output_power: 20
ntripcli:
address: 159.89.145.103
mount_point: MP2743a
password: '***'
port: 2101
username: u97593
serial:
baud_rate: 38400
device: ttyEXTS0
tcpcli:
address: localhost
port: 10001
tcpsvr:
port: 10000
device:
privacy_policy_accepted: true
role: null
usage_analysis_accepted: true
logging:
logs:
base:
autostart: false
format: RTCM3
started: true
correction:
autostart: false
format: null
started: null
raw:
autostart: false
format: UBX
rinex_options:
logging_interval: 1
marker_name: null
pole_height: null
satellite_systems:
beidou: false
galileo: false
glonass: true
gps: true
qzss: false
sbas: false
started: true
solution:
autostart: false
format: LLH
started: true
settings:
debug: false
interval: 24
overwrite: true
position_output:
output1:
io_type: bluetooth
nmea_settings:
bluetooth:
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
serial:
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
tcpcli:
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
tcpsvr:
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
settings:
bluetooth:
format: NMEA
serial:
baud_rate: 38400
device: ttyEXTS0
format: ERB
tcpcli:
address: localhost
format: ERB
port: 9000
tcpsvr:
format: LLH
port: 9001
output2:
io_type: 'off'
nmea_settings:
bluetooth:
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
serial:
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
tcpcli:
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
tcpsvr:
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
settings:
bluetooth:
format: NMEA
serial:
baud_rate: 38400
device: ttyEXTS0
format: ERB
tcpcli:
address: localhost
format: ERB
port: 9000
tcpsvr:
format: LLH
port: 9001
positioning_settings:
elevation_mask_angle: 15
glonass_ar_mode: true
gnss_settings:
positioning_systems:
beidou: false
galileo: true
glonass: true
gps: true
qzss: true
sbas: true
update_rate: 5
gps_ar_mode: fix-and-hold
max_vertical_acceleration: 1
positioning_mode: kinematic
snr_mask: 35
Hi Adis,
Thanks for the details!
Please check your PMs. I’ve reached out to you there. The next steps are easier to handle in a private chat.
