I found a bug. If I set the RS3 to Automatically start logging when it turns on, in my case where I use the default option and change the update time to 1 sec, it will create a 1 second file. I ended up with thousands of them while flying LiDAR today and had to restart the flight 1/2 way through. Luckily I noticed it stays recording to one file if not set to automatic start. I assume it isn’t supposed to create 1000’s of 1 second files?
Hi @KN1,
Could you please double-check that the receiver is on the latest firmware version (31.7)? To see that, please tap on Settings > Firmware updates.
That fixed it. Thanks
