Bug in iOS Flow App with respect to codes
Hello,
I believe that I discovered a bug today in Emlid Flow for iOS (survey subscription). I am on the latest October build. When you attempt to key in a point, the feature code will not hold. It still says no code after you select ANY code (from Emlid code library). In order to get a code to hold, you have to save the feature without a code and then edit the feature to then apply it. This also happens when trying to create points from the Traverse command. Thanks and please advise Emlid support! I do not have an android device to test either.
P.S. Running iOS 17.6.1 on iPhone 11.
I just discovered that if I put coordinates in first, the code will take. This is still a bug of sorts, as the optional code entry comes before the coordinates in the point creation section. It should flow (pun intended lol) from top to bottom, right?
Hi @Zaz5400,
Thanks for reporting the bug. However, I couldn’t reproduce it. I tried to reproduce it in two ways based on your description:
  1. Create a point by entering the coordinates first, then choosing the code after
  2. Choosing the code first, then entering the coordinates after
Both resulted in points with feature codes saved.
I use Emlid Flow 11.5 on an iPhone 12 mini, iOS 17.6.1. Could you share a screen recording of the issue so I can try to follow the steps you took exactly?
Thank you!
Interesting. I will do more testing and report back.
Sure thing. Please keep me posted on the results of your testing. Thank you!
