Would it be possible to transplant Navio into a Blade QX 350.
If if one has to cut open the top and make it a convertible
Yes, clearly a novice with high hopes to change this.
Which version of Blade QX 350 do you have in mind? 1, 2, 3?
I’ve seen some photos of QX 350 with upper cover removed and pixhawk installed, so that should be doable:)
