Hello,
I would like your help regarding the inaccessible download of BNC at this address: https://software.rtcm-ntrip.org/svn/trunk/BNC.
Following the procedure in step 10 of the installation manual, I compiled Qt.
I’m blocking now in step 11 to download the latest version of BNC.
I thank you for your valuable advice.
Sincerely.
Hello,
Do you know of a valid BKG Ntrip Client (BNC) download link under Windows 7 ?
Sincerely.
https://register.rtcm-ntrip.org/cgi-bin/registration.cgi
free-off-charge
https://bkgmonitor.gnssonline.eu/cgi-bin/bkgmonitor.cgi?mod=Map&caster=euref-ip.net&lang=en
euref-ip.net port 2101
Good luck
I will also give you a detailed advice. After selecting the nearest station, for example, like here, use Google and check what ‘data provided’ is (example JOE2). The more GNSS systems, the better
Good evening,
I am very happy to receive your precious help.
I will connect and test all that.
During your work, have you tested RtkLib with Ublox-Neo M8T in Ntrip server mode with Rover and / or the other Base + Rover mode?
Thanks again.
Sincerely.
