Good morning friends, I recently updated my reach rs and with the flashing all the configuration with which the equipment worked perfectly was deleted. I want to know what configuration you recommend since I try to put the previous data and not all the options appear. I am writing to you from Guatemala.
Thanks for helping.
Hi Mario,
The configuration depends on your use case. Do you have a single Reach RS and work with the NTRIP? If so, you can check this guide.
Or you also have the base, as I see from your previous posts on forum, and work via LoRa in Base and rover setup? If so, this guide may be of help.
Gracias!
