Hi Emlid Community, I am buying a Reach M+ to attach on my UAV. It will be an independent circuit to register the precise coordinates in order to make a Post Processing Kinematics (PPK) integrating with the base station data (also a Reach M+).
I am building the same circuit for both Reach M+ (base and rover), and I need a Power Supply for each of them. I saw on documentation that the Reach M+, powering using JST-GH ports, needs 5v of power supply.
Aiming to compact the system, can I use a 2S LIPO (7.4v) or LIFE (6.6v) battery on each system? What is the indicated capacity to keep it on along 3 hours? Maybe 1000 mah?
Please note that we recommend using a USB 3.0 or 4.75 - 5.5V source. The current consumption should be up to 200 mA. For further details, please check the Reach M+ and Reach M2 specifications in our docs.
