I’m desperate to find the step by step to post process a survey (correct base station coords with using COORS logs), then correct the coords of the surveyed points and output a CSV with the corrected points. Pulling my hair out trying to find docs. The Emlid post processing doc for RTKLib is okay but it only briefly mentions correcting the base and doesn’t cover it as a two-step process to eventually get the corrected rover points. Found a forum example of the process to correct the base but it was for then going back out to do the survey and manually entering the base coords.
I don’t want this thread to get to big and go off on tangents so I’ve started a new thread about it here:
