@TB_RTK Do i not need any base data at all then. The results posted by yourself and @igor.vereninov looked perfect. The problem is I am having difficulty recreating them.
I have just followed last instructions and my green fixes have disappeared when I put into Plot.
When calculating the position for the base your base goes into the rover field and NCAS data in the base station field
RINEX OBS Rover:
baseraw.obs
RINEX OBS Base station:
ncas187r.17o
RINEX NAVβ¦:
baseraw.nav
@igor.vereninov it is still giving me an incorrect position, the position you generated earlier in the thread looked correct. What settings and process did you use for that? Thanks
Try this config. tbconfig.zip (1.5 KB)
Use rover.obs file, ncas file in base and rover .nav + .sbs in the option below
This will give you absolute position of rover.
