The Shifted Mark and the Known Point have to be separate entities? Say, I measure a brand new point as the Shifted Mark, and then I use the Base Point I used the day before as a Known Point? Would that work? Am I understanding correctly?
What if I was to measure the Base Point from the previous day as the Shifted Mark and then I use the known coordinates from that same point as the Known Point? Would that work as well?
The shifted point and the known point are the same entity.
On the first day, you collect the control point. At the beginning of every other survey day, you collect this point again. If it has a shift in coordinates from the first day, you can apply the base shift to eliminate a difference.
So the Known point in the RV3 is always the coordinates from the first day. The Measured point is the coordinates of the same point from another survey day.
I use it on my workflow. The first time I did it on my own I actually did it like he displays on the video, but for some reason it didn’t work out for me, I must have made a mistake on one of the steps.
