Base shift max. distance
i was wondering how far away is “okay” to use base shift, i.e. i have a perfect place to put a reference mark -bolt + epoxy-, but is impossible to put a tripod or bipod and is not a safe place for the gnss antennas because is too close to a high way. The next good place it’s a field 100 meter away from the mark i like put, perfect sky view, but ill have to make a monolith.
Hi @Diego_a,
Good to see you here again.
100m is absolutely fine. However, good to keep in mind that the further you go from the calibration point, the greater the difference you will have in your measurements.
