When I apply a base shift, if I leave the project and return, the shift is no longer applied.
Going to the project’s menu to check the base shift, it still shows as being active, but it definiutely is not.
I have to delete the existing shift, chose the same points again, and it will return.
This is a repeatable bug as it happens every time I leave the project.
