Base setup for PPK without known point
if i had to use Emlid rs2+ for base station for PPK correction and there is no known point available in the area what should i do?
what i tried is in emlid rs2+ i keep input as ntrip service and output off, (it shows fix solution) recorded raw data but in ppk correction all point are flot solution only 1.7% fix i need 100% fix solution…HELP
I was using mavic 3E with dji rtk but rtk data has issue si ppk was my fall back and its not working as I expected
Need more detail here but I am assuming you are using Emlid Studio. If that’s the case, you may need to adjust your settings with respect to using glonass/galileo (on/off/fix and hold). Also, hopefully you were logging at least 1hz at your rs2+ base.
Hi, @bahraindrone,
Welcome to our Community Forum.
If there’s no known point nearby, you can use the PPP technique with your Reach RS2. After surveying, submit your base’s raw RINEX data file to a PPP service (like OPUS in the USA or NRCAN globally) to obtain precise coordinates for your base. This will allow you to post-process your rover (Mavic) data relative to an accurate base position.
Regarding the fix issue, feel free to share the files with us here or on our support email address (support@emlid.com), and we’ll investigate to help troubleshoot. Also, @Zaz5400’s comment about settings on Reach is a point to check on setting up the reach.
