Base/Rover w LoRa floats
Greetings, I’ve got Base (RS2+) and Rover (RS3) in an open area. Rover not more than 600ft from base while collecting GCPs. Both receivers logging data for PPK stop and go. After the first two GCPs, Emlid Studio shows float solution. Shouldn’t I be getting better connection than that in a good environment?
Can you upload the raw-data? Use wetransfer or similar.
Messaged you a dropbox link, Christian. Thanks for looking into this.
Hi @petehernandez, I’d like to investigate this issue. Could you share the data with me? You can also send an email to support@emlid.com.
Let us know what comes of this!
I just send a dropbox link with the log files from base and rover.
Hi, for an update on this thread. The data looks okay. We reprocess the data and adjusted the setting:
This helps to increase the Fix solution to 99.8%.
Thank you!
