There’s been some threads in the past about this but with various responses. I would like to know if it is better (or matters much) to set the Base as Static in the GNSS Settings. I am interested in RTK surveying (no post-processing) using the RS2 with a Base set up manually over a known datum and communicating with a Rover via LoRA.
I’m curious about this as well.
It only matters if you are trying to obtain a position for your base with correction input enabled and base setting position coordinates are not populated.
So, if correction input is off, static or kinematic has no function.
