They should include an off-line base map and solve the hostpot problem since some reach rs + do not connect to the wi-fi network
Hi! What do you mean by “some reach rs+ do not connect to the wi-if network”?
some reach rs + do not connect to the wi-fi network, and there are many
Please, make sure, that you have last versions of the software installed. In the last update, there is a fix for a hotspot problem - ReachView v2.21.2 - #2 by tobias-dahms
Hi Carlos,
Could you please describe your actions in more detail?
Please, try to reproduce this guide step by step and tell us on which step do you encounter issues.
Can only recommend installing the newest dev-software. Worked like a charm on my RS+ units.
