Hi
I have RS2+. I just need a base log recorded with 1 Hz for trajectory process. I did that several times in the past I could just turn on the base wait 2 hours next turn off the base and after that I had possibility to download logs. Today after I used RS2+ several times I get very short logs… every files with one minute log so there is hundreds of files because the base was turn on for several hours. What happens why logs are split to several seconds files ??? Firmware 31.8
Hi Miron,
I’ve contacted you via email. Let’s continue the discussion there to keep all information in one place.
