Hi, I was testing the REACH today, both units ran a few minutes in float mode. However, there was no log files in the base unit, which is really weird. I wonder if there is anything wrong with the procedures? I clicked stop button first and then unplugged the power cable.
You find the log files on the Rover.
Is it the Reference file you are referring to? thanks,
Yes, Each restart 2 files are generated reference (base) and rover.
You can set up this in rovers config.
hi, i have the same problem…
where is the log base file?
thanks a lot
Hey!
If you used real time corrections, the log will show up on the rover as a reference log.
If you do not have a connection, you will need to set Base mode output to file and it will be available for download.
ok, perfect…
