Is there any simple doco on setting up RS2 Base to send correction to Rover over NTRIP.
There is doco on receiving correction on Rover over NTRIP from a VRN.
This is important when working in Urban areas where the Lora radio can only go a few hundred metres (Yes I have adjusted Speed etc as per doco)
I though that once a Mount Point was registered the Base could log onto say RTK2go and then broadcast the corrections but I cant see the Mount point from the rover.
For rtk2go, just follow the instructions on their site. Works like a charm (with the odd limitation that it only broadcasts 30 sats, where the rs2 usually can transmit 35-40 sats).
