Hello all
Could you help me, please?
I’m trying to figure out how to set up an RS2+ as a base and the second as a rover.
I am in a place where I do not have a well-known point (For setting up the base), but I do have an NTRIP connection.
Show my point what the correct procedure is so my base gets NTRIP corrections and is forwarded to the rover.
Looking for absolute accuracy
Thanks a lot for your answer in Base Mode, you start averaging (would recommend the 30 min option)
There is an average single - float- fix which one should be used?
Also the average time every 2 min for 30min total or 30m average?
To place the base accurately, you can use Average FIX. As for the averaging time, the default 2-minute option can be enough to obtain cm-level accuracy, although the 30-minute option suggested by Christian is also good.
You can configure correction streaming either via LoRa radio or Emlid Caster. For the second, you’ll need a stable internet connection on your working site.
