i have connection my 2 reach with rfd radio (UART connection).
i don’t know how configure the base and rover for radio comunication
Base configuration :
i have to configure Input correction ?
I have to configure position output?
i have to configure base mode?
how to configure this field?
you find it all via the search… even all the problems with 3DR.
Some info:
Hopefully the 3DR is working “normally”. If not, it can be checked with a Software, called 3DRRADIOCONFIG.
“Normally” only one 3DR device has a USB-conn. the other one has only a serial line. And this is what I am describing: BASE
3DR with USB is connected to the BASE-Emlid:
Output path for corr. : serial --> USB
Speed: 57600
Output format: rtcm3
and “I” have:
RTCM3 Messages can be: 1002, 1006, 1008, 1010, 1019, 1020
GPS_GLONASS_5Hz.cmd ROVER
Input source for base corr: serial --> UART …if no USB !!
Speed: 57600
…This is my config…hope it helps
G.
thanks, but i have connect the boot device with uart.
and i don’t know how i configure the base and the rover…
an example "firmware 2.2.5"
for the base wich field i have to compile?
-correction imput?
-position output?
-base mode?
