Hi, I’ve encountered some Barometer issues
If i run the Python or C++ example, it seems to be read ‘random’ values.
Once powered by USB:
pi@navio-rpi /opt/src/Navio/C++/Examples/Barometer $ sudo ./Barometer
Failed to read device(-1): Input/output error
Temperature©: 37.385159 Pressure(millibar): 969.417236
Temperature©: -532.174377 Pressure(millibar): -2477.178467
Temperature©: -267.773163 Pressure(millibar): -442.001068
Temperature©: -107.103722 Pressure(millibar): 536.828918
Temperature©: -34.879921 Pressure(millibar): 856.569458
Temperature©: 10.914048 Pressure(millibar): 935.492249
Temperature©: 28.299593 Pressure(millibar): 975.826538
Temperature©: 37.845177 Pressure(millibar): -1058.129395
Temperature©: 23.703375 Pressure(millibar): -1029.307617
Temperature©: 38.148769 Pressure(millibar): -767.760864
Temperature©: 38.156048 Pressure(millibar): -109.741173
Temperature©: 38.165775 Pressure(millibar): 369.003357
Temperature©: 38.179008 Pressure(millibar): 578.783142
Temperature©: 38.148304 Pressure(millibar): 947.352112
Temperature©: -532.174377 Pressure(millibar): -2477.784180
Temperature©: -532.174377 Pressure(millibar): -2476.995117
Temperature©: -500.578278 Pressure(millibar): -2217.255859
Temperature©: -256.742737 Pressure(millibar): -366.013000
Temperature©: -107.465889 Pressure(millibar): 552.729248
Temperature©: -32.446495 Pressure(millibar): 835.202637
Temperature©: 23.997505 Pressure(millibar): 965.590698
Temperature©: 33.601387 Pressure(millibar): 987.958618
Temperature©: 35.316860 Pressure(millibar): -1052.976440
Temperature©: 9.288847 Pressure(millibar): -1000.039795
Temperature©: 38.224205 Pressure(millibar): -562.157104
Temperature©: 38.205013 Pressure(millibar): -74.185623
Temperature©: 38.200912 Pressure(millibar): 343.133759
Temperature©: 38.213680 Pressure(millibar): 784.144470
Temperature©: 38.206207 Pressure(millibar): 944.163879
Temperature©: 38.221622 Pressure(millibar): 1006.430298
Temperature©: -532.174377 Pressure(millibar): -2476.702637
Temperature©: -346.333435 Pressure(millibar): -1008.203613
Temperature©: -197.056976 Pressure(millibar): 31.665390
Temperature©: -62.683964 Pressure(millibar): 758.680786
Temperature©: -10.437016 Pressure(millibar): 887.257568
Temperature©: 20.528704 Pressure(millibar): 957.517334
Temperature©: 32.776104 Pressure(millibar): 985.943054
Temperature©: 35.015385 Pressure(millibar): -1052.362061
Temperature©: 20.846060 Pressure(millibar): -1023.484314
Temperature©: 38.270920 Pressure(millibar): -770.584717
Temperature©: 38.249878 Pressure(millibar): -305.971008
Temperature©: 38.262184 Pressure(millibar): 378.497040
Temperature©: 38.266289 Pressure(millibar): 677.893372
Temperature©: 38.280251 Pressure(millibar): 897.811035
Temperature©: -532.174377 Pressure(millibar): -2522.287842
Temperature©: -532.174377 Pressure(millibar): -2476.644531
Temperature©: -287.587097 Pressure(millibar): -580.763245
Temperature©: -122.883430 Pressure(millibar): 456.219452
Temperature©: -47.708389 Pressure(millibar): 788.018433
Temperature©: 5.964398 Pressure(millibar): 958.096924
Temperature©: 29.569208 Pressure(millibar): 978.432495
Temperature©: 38.799625 Pressure(millibar): -1060.074585
Temperature©: 29.650400 Pressure(millibar): -1041.427979
Temperature©: 4.639282 Pressure(millibar): -990.672058
Temperature©: 38.294144 Pressure(millibar): -302.045868
Temperature©: 38.300236 Pressure(millibar): 251.764145
Temperature©: 38.313667 Pressure(millibar): 579.175842
Temperature©: 38.319950 Pressure(millibar): 877.822876
Temperature©: -532.174377 Pressure(millibar): -2517.187012
Temperature©: -532.174377 Pressure(millibar): -2476.423340
Temperature©: -415.722748 Pressure(millibar): -1538.396729
Temperature©: -244.504211 Pressure(millibar): -282.886871
Temperature©: -92.305130 Pressure(millibar): 607.445618
Temperature©: -40.402786 Pressure(millibar): 841.018677
Temperature©: 13.484530 Pressure(millibar): 941.066223
Temperature©: 30.867413 Pressure(millibar): 981.309082
Temperature©: 38.937855 Pressure(millibar): -1060.356201
Temperature©: 27.538628 Pressure(millibar): -1037.124023
Temperature©: 38.339806 Pressure(millibar): -700.022461
Temperature©: 38.351513 Pressure(millibar): -123.534454
Temperature©: 38.353832 Pressure(millibar): 435.270538
Temperature©: 38.361244 Pressure(millibar): 770.265137
Temperature©: -532.174377 Pressure(millibar): -2526.429199
Temperature©: -532.174377 Pressure(millibar): -2476.232422
Temperature©: -263.986938 Pressure(millibar): -415.747375
Temperature©: -112.761093 Pressure(millibar): 508.223450
Temperature©: -35.712276 Pressure(millibar): 825.575562
Temperature©: 0.826348 Pressure(millibar): 946.372742
Temperature©: 27.951599 Pressure(millibar): 974.453308
Temperature©: 38.398102 Pressure(millibar): 1029.057495
Temperature©: 23.243555 Pressure(millibar): -1028.370605
Temperature©: 38.398300 Pressure(millibar): -771.421143
Temperature©: 38.371433 Pressure(millibar): -261.746887
Temperature©: 38.385921 Pressure(millibar): 282.010620
Temperature©: 38.394131 Pressure(millibar): 601.599060
Temperature©: 38.399025 Pressure(millibar): 878.810303
Temperature©: -532.174377 Pressure(millibar): -2502.920898
Temperature©: -532.174377 Pressure(millibar): -2476.090820
Temperature©: -423.792511 Pressure(millibar): -1601.363525
Temperature©: -199.727234 Pressure(millibar): 9.370508
Temperature©: -68.685577 Pressure(millibar): 709.873291
Temperature©: -12.452148 Pressure(millibar): 915.680237
Temperature©: 24.879492 Pressure(millibar): 967.215576
Temperature©: 38.309296 Pressure(millibar): -1059.075195
Temperature©: 23.903608 Pressure(millibar): -1029.715820
and another time powered by a 4S battery
Temperature©: 39.342159 Pressure(millibar): -875.197266
Temperature©: 39.307617 Pressure(millibar): -156.762894
Temperature©: 39.298485 Pressure(millibar): 388.230469
Temperature©: 39.320648 Pressure(millibar): 622.305786
Temperature©: 39.323830 Pressure(millibar): 931.716309
Temperature©: -532.174377 Pressure(millibar): -2482.022949
Temperature©: -532.174377 Pressure(millibar): -2472.262695
Temperature©: -370.579620 Pressure(millibar): -1210.862183
Temperature©: -119.129845 Pressure(millibar): 493.748840
Temperature©: -42.431591 Pressure(millibar): 803.280334
Temperature©: 11.310713 Pressure(millibar): 933.820801
Temperature©: 33.696476 Pressure(millibar): 985.521118
Temperature©: 39.107121 Pressure(millibar): -1060.701294
Temperature©: 9.956215 Pressure(millibar): -1001.387085
Temperature©: 39.395294 Pressure(millibar): -666.494812
Temperature©: 39.391254 Pressure(millibar): -149.518509
Temperature©: 39.378483 Pressure(millibar): 367.473663
Temperature©: 39.360485 Pressure(millibar): 630.795227
Temperature©: 39.386688 Pressure(millibar): 898.622559
Temperature©: -532.174377 Pressure(millibar): -2448.174561
Temperature©: -532.174377 Pressure(millibar): -2472.115234
Temperature©: -451.721710 Pressure(millibar): -1819.593628
Temperature©: -227.246796 Pressure(millibar): -168.056305
Temperature©: -84.266541 Pressure(millibar): 642.221191
Temperature©: -24.541651 Pressure(millibar): 892.804443
Temperature©: 18.629314 Pressure(millibar): 950.528137
Temperature©: 29.170595 Pressure(millibar): 974.963928
Temperature©: 38.660267 Pressure(millibar): -1059.790527
Temperature©: 25.451670 Pressure(millibar): -1032.870728
I’m not sure if it is related, but i had an shocking experience with one of my flights where my quad would not come back to the ground it was flying up and up and up, even throttle to down-most position did nothing, i just managed to bring it down again by switching to Acro mode and coming down with a swoop
Within the flight, my barometer was not covered, but those numbers coming from my desk
Any help is appreciated.
