So why would I be getting “bad logging” on my Navio2 ?
Any one have an idea ?
Hello.
This error can be caused by insufficient space on SD card. Do you expand your file system?
Also check your SD card class or try another one.
Yes I expanded via raspi-config. Will fly in a day or 2 and let you know if the problem still exists.
On a separate not, I notice that on my flight this weekend i got about 7 GPS glitch errors
Hi, I had this same error on last Saturday, with lots of space, I fixed with “fsck /dev/device/”
where dev/device must be filed with your S.O names.
But please, this command works for me , If you have bad blocks I don’t know will be the results, please take care.
To discover :
df -m
or
mount
Thank you Rob.I set my LOG_ to both file and Mavlink…I hope this helps
