okapy
September 5, 2017, 12:38am
1
It is necessary to provide following information to get help:
Image and ArduPilot version.
Detailed problem description. How does observed behavior differ from the expected one?
Your step by step actions.
Picture of the setup and connection scheme.
If using any additional hardware please provide exact make and model.
u-blox 0 HW: 00080000 SW: EXT CORE 3.01 (107900)
Frame: QUAD
APM:Copter V3.4.6 (e707341b)
I am trying to connect PX4FLOW to Navio 2 and let it fly.
However, if PX4FLOW is set to Enable, the barometer gets abnormal.
And the propeller stops.
Can I use PX4FLOW in Navio 2?
http://ardupilot.org/copter/docs/common-px4flow-overview.html
I worked in the procedure described here.
pi@navio:~ $ i2cdetect -y 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: – – – – – – – – – – – – –
10: – – – – – – – – – – – – – – – –
20: – – – – – – – – – – – – – – – –
30: – – – – – – – – – – – – – – – –
40: – – 42 – – – – – – – – – – – – –
50: – – – – – – – – – – – – – – – –
60: – – – – – – – – – – – – – – – –
70: – – – – – – – 77
Can you try lowering the i2c_baudrate in /boot/config.txt to 400000? This should help
okapy
September 5, 2017, 7:39am
3
Thank you for your reply.
[Before]
pi@navio:/boot $ cat config.txt
[all]
dtoverlay=pi3-disable-bt
dtoverlay=navio-rgb
dtparam=spi=on
dtoverlay=spi0-4cs
dtoverlay=spi1-1cs,cs0_pin=16,cs0_spidev=disabled
dtoverlay=rcio
dtoverlay=navio-rgb
dtparam=i2c1=on
dtparam=i2c1_baudrate=1000000
Additional overlays and parameters are documented /boot/overlays/README
Enable audio (loads snd_bcm2835)
#dtparam=audio=on
start_x=1
gpu_mem=128
[After]
[all]
dtoverlay=navio-rgb
dtparam=spi=on
dtoverlay=spi0-4cs
dtoverlay=rcio
dtoverlay=navio-rgb
dtparam=i2c1=on
dtparam=i2c1_baudrate=400000
#dtparam=audio=on
start_x=1
gpu_mem=128
Is this OK?
This should then become dtparam=i2c1_baudrate=400000
system
(system)
Closed
December 14, 2017, 12:38am
5
