I set up my RS2 base the other day over an unknown point and used the average single (2 min.) to establish a relative position. Then went on to locate some boundary points with the rover. Since I had the base logging over 4 hours I sent it off to OPUS for processing the next day. My problem is that, I believe, I should have written down the base coordinates before shutting down the unit as I can’t seem to find them other than the Rinex file.
I’ve received the OPUS solution so I can re-set my base on it and relocate the points, but would rather not.
Thanks, Rob
Disregard that last post. I just found the base position listed at each point that was collected. Too impatient
Hi @Beartow,
Thank you for posting the solution. It will be useful for others to know that if you collected the points, you can check the base position in Emlid Flow:
