is there an option that the base station automatic chooses a new position when i am moving in the field?
For example. I start atvone point and the base is automically positioned a few meters next to me. But when i am walking on with my emlid, the base is fixed at that point. Even when i am walking a few hundred meters away from it.
Although the base unit recalculates its position regularly, the position that the base transmits to the rover stays the same. And this position is saved in the Base settings. As @davehofer1993 said, you have to tap on the “Average Again” button on the Base settings tab when you change its location if you’ve set up the base using the position averaging with single, float, or fix solutions. Alternatively, you can reboot the unit as it will also recalculate its position in this case.
If you’ve chosen the Manual method and placed your base on a known point, you have to add the coordinates of the new point when you change its position.
Nop… not really. You’ll get more or less the same at that distance, as the ionispheric and atmospheric disturbances or more or less the same over 3 or 150 meters.
Additionally, when you move your base, you will also have an error from a new GNSS measurement and from the new physical placement.
Without having done the math on it, I’d say you can probably get out to 2-3 km and still get the same precision.
Yes, you described it very well, my colleague wizprod.
I would like to add that you can quantify a theoretical accuracy error with the following mathematical formula.
Horizontal Accuracy= 7mm+1mmKm(separation from the base in kilometers)
Vertical Accuracy= 14mm+1mmKm(separation from the base in kilometers)
now, without knowing what kind of work you do, I would recommend you to leave topographic marks in the project to continue advancing, always with points that are linked to each other, with a new position calculated in average single, you can easily introduce an error of 90cm.
