Autocad en Emlidflow360
Me pasa que al hacer la importación del archivo cad en el Emlid Flow 360 del PC, posteriormente no logro visualizarlo en la aplicación Emlid Flow.
Alguien sabe porque razon sucede esto.
saludos
Hi @vladimirmera,
We reply only in English here, so I’ll switch to that.
Currently, we’re upgrading our database infrastructure, and that’s causing some sync issues on our side. Please don’t delete or reinstall the app. The devs are actively working to get everything fixed as quickly as possible. I’ll let you know as soon as we have any news.
In the meantime, to help you keep going, I’d suggest exporting the project from Emlid Flow 360 and manually importing it into Emlid Flow.
Tal vez es algo de sincronización con el dispositivo móvil. Podrias probar re-logearte en el teléfono o libreta de campo.
Hi @vladimirmera,
Do I understand correctly that you’re using an Android device? We’ve released a fix in Emlid Flow version 13.1 that should help with the crashes you’ve experienced. Could you update the app? Please let me know how it’s working for you.
Processing large amounts of data might take a few seconds, so it’s best to wait before opening the Survey tab. If you open it and the app crashes, it will automatically retry the next time you start.
