Hello,
I am doing a glider with Navio2 with arduplane 3.8.5 and I cant find something about Autologin or some script.
Its possible to start arduplane in the air ?
Thanks for answer.
Hi @R1val,
Why do you want to start arduplane in the air? Could you please tell more about your application?
Hi @tatiana.andreeva
I am doing with my mates project about glider with a meteo probe. The glider will flyup on helium ball and after his destruction, the aircraft will be operated by Navio. I have a few points for this project:
- Autostart the aurdupilot after start raspberry
- Autostart some mission autostart of a predefined mission or the flight itself to some defined “Home point”
- I do not know whether the mission planner must be part of the product or the mission can be defined in advance.
Thank you for answer.
R1val
Hi @R1val,
You can configure autostart using the command @vikeyer shared above or just specify “enable on boot” option during configuration with emlidtool.
Check Planning a mission with Waypoints article in ardupilot docs, it describes the workflow.
You can use freely available GCS software for mission planning, such as Mission Planner and QGroundControl.
